eh? Turning on fresnel you definitely can still control the amount. With fresnel on 0% reflection means no reflection through to 100% reflection meaning full reflection.
edit addition: once you turn on fresnel the reflection color works like a ‘filter’. White means reflect all colors, i.e. mirror like. A non-white color means reflections are coloured like that, this is like the metallic workflow.
Meh… test it out for your self and convince me if you can
Here 5 red balls with varying reflection and Fresnell ON:
0% 25% 50% 75% and 100%
For some reason 50 and 75 has more reflection than 100.
What is the Rhino version used in the first image, and what in the second image? Anyway, the second is what I see here as well - but then again, I am working with the latest dev build I cranked out myself
That’s the price NOW. When I bought it it was more than $250, I’m TRYING to think I’m remembering I went for the “ti” adding more than a hundred to THAT price, but that’s only recollection. No, BACK THEN it was EXACTLY as I’ve presented. Maybe a shift from PROVING I’m wrong and you’re right, we could shift the conversation to STILL with a card at $1000 we’re still getting NOISE at the END of a render that took the best part of an HOUR on someone’s card here that claims to be the hi-end version YOU’d mentioned ? That’d be nice.
With ALL of that said, I STILL get the results I mentioned before on a $150 CARD (!)
STD RTR Mode: ZERO POINT ZERO seconds per animation frame
30 seconds per animation frame in NEON mode.
unuseable time to an unusable result “Raytraced”
NOISE in an “IMPROVED” image that “LOOKS FINE” -
Nope.
In this context, dealing with Card-shaming is actually pretty entertaining ! Thanks !
Excellent !!! May be FIXED ! What’s the spec’s on the card ? Is this kind of performance available to the basic or intermediate user or is it limited to high-end cards ? THIS looks WONDERFUL !
$499 (FIVE HUNDRED DOLLARS) Card. Reasonable price on a new build. ALMOST within reach for a “free” solution ! Anybody see this on a GTX-1050ti ? Prob’ly similar results ?
Note that the GTX 1050 Ti has 768 compute cores compared to the 1920 compute cores on the GTX 1070, and 1280 compute cores on the GTX 1060. The GTX 1050 will probably render the same scene with the same amount of samples a bit roughly over twice the time of the GTX 1070.
I cannot reproduce this. Having an active viewport with Raytraced with either sampling still in progress or already finished doesn’t see a restart of sampling when clicking on the Mesh Tools tab or any of the tools on the tab - really only when a command is actually run.
In your video it looks like the size of the viewport changes due to the toolbar docked to the left. You can see that it increases width a pixel or two to the right. That constitutes a change in size of viewport, thus triggering a restart.
Your tabs for the mesh tools sidebak look a bit wider than on mine, seemingly because of bigger pad. The tabs for your top toolbar also look like the have bigger padding. I don’t know why that happens, but it isn’t something Raytraced can control. I’m guessing you’re running with a scaled windows UI?
I see. 4K screen thing again perhaps?..
Well I don’t do mesh so just noticed. not a big issue…for me…
And I suppose you don’t use mesh in raytraced viewport.
Not much mesh editing directly in Rhino for me no - the tools are too different from Blender and compared to Blender rather limited still to feel really comfortable using them. But with the good work of @Jussi_Aaltonen in v7 this will be so much better (:
