Another UI color question
While I was tinkering around I seemed to have made my menu unreadable and can’t figure out how to change it. Any ideas what could have gone wrong here?
maybe it helps to tick the “Only display modified values” checkbox
I suspect it is one of the Content Background colors you are looking for, but I am not sure what you are pointing out in that image
Thanks Gijs!
The big issue is that certain menus, like the one in the Script Editor, have black text with a dark background.
For additional context, i’m a blind/low-vision Rhino user and rely on some custom settings to be able to see Rhino better (making the background dark, making text bigger, etc.) I initially thought perhaps i had messed something up in my custom settings, but after a factory reset I still encountered the same issue with this menu.
(The issue is with menu where the blue band in the center of the screen is highlighting black text. This is very low contrast and almost impossible for me to see.)
I realized that the problem comes from how Rhino interacts to Windows Contrast Themes. These are a systemwide accessibility setting in Windows.
After a quick test toggling the contrast theme I use (a system default called “Night Sky”) on and off i confirmed that once the theme is turned off, the menu looks normal again.
However, the contrast theme is something that I need to have on at all times to use my computer, and turning it off and on a lot can create strange glitches. I’ll send a note to Windows about the issue as well. If it gets fixed on either side I’m happy. Fortunately it’s not all menus. The one I am testing here is the ScriptEditor.
If you’d like to replicate the behavior in Windows just go to Contrast Theme Settings > Night Sky > Apply (I also like to set up the keyboard shortcut it allows so I can quickly toggle it).
Warmly,
Paul
Here’s another example of it not working with one of the tool settings menus
