Hi All. I have previously reported inconsistency in the output from Rhino’s SunStudy “Animation tool”.
This is another example of the same issue. The RenderPreview looks OK but the FullRender is bad.
I have tested with different variations of geo-location, date, time of day and varying time-increments.
The inconsistency is the same across all experiments, and I really wish for a solution for this issue.
The problem is the same with any file and any geo-location, date and time. If the Sun & Sky is the only active lighting. The shadows “jumps” from hard to soft at random intervals in the selected Sun-Study. It was also the case in 6.
Previous examples provided was a “tea-light”.
I can WeTransfer a large file if you provide me with a link. The Discourse-system ignored it.
Hello - It would just be useful to have a simple file that already shows the problem - a box is fine, but knowing your settings and your setup for sun animation to make the bad thing happen is what I am after. Rendered mode or full render, timing, etc etc.
OddLight in the interval kl. 02-20 at all the following times:
Kl. 04:10 + 04:20 + 05:10 + 05:30 + 06:10 + 06:30 + 17:30 Sete_Promenade_NoSkylight_Cropped.3dm (8.2 MB)
Hello again. I have now moved to Rhino 7 SR 8 + Enscape 3.1 and experience the same problem with the Rhino Sun at arbitrary times of the day. In this example from 16. september - it is around kl. 12:00. 16xLogo_Shadow_Enscape_3.1.pdf (380.4 KB)
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 3-30-2021 (M-D-Y).
Primary OpenGL: NVIDIA Quadro RTX 4000 (NVidia) Memory: 8GB, Driver date: 6-21-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 471.11
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-21-2021
Driver Version: 30.0.14.7111
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
I take it that you are referring to the issue with hard and soft shadows when running sun study?
I tested that fix in Rhino 7.7 and again now in Rhino 7.10. With the “tea-light” file that you provided, everything seems to work as intended. If you can reproduce a shadow issue with Enscape and V-Ray not loaded, please provide a simple scene that I can test.
Hi Wim. Thanks. I will test again without Enscape 3.1 and V-Ray 5 loaded.
I have during the testing wondered about the CreateSunStudy North-angle.
I need to specify it as “Clockwise from Y” and It’s not possible to set DST.
When having a Project North set to 296.6 degrees from X-axis (0 degrees)
I only get the correct shadows if I type in the North to be 117.85 from Y(!)
Hi. It looks like the soft/hard-shadow issue has been solved by @Nathan, which is really nice. Thanks.
I would like to return to the question about the lack of DST-support + actual orientation of the Sun and the (lack of) precision of the sunrise, meridian and sunset compared to timeanddate.com for my location (Kopenhagen, Denmark). As I understand it, it is NOT, needed to have the RhinoSun set to On, when performing a OneDaySunStudy? - I need to know the exact time of shadows cast on the street running vertically through the provided example. I have rotated the model-north to match the actual north.
When using the normal RhinoSun, the precise time with no shadows on the street is kl. 14:30 on 16. Sept. 2021. Similarly the Sun should be in South at kl. 13:05 on the same date and East at kl. 07:30. According to the website timeanddate.com the sun should rise in CPH at kl. 06:43 and set at kl. 19:24.
The Zip-folder contains still-images for every 5 min between kl. 04.30 & kl. 19:00 - from Rhino 7 SR9.
The PDF-file show 12 snapshots from Enscape 3.1 (from Rhino 7 SR9) - around 2 hours difference(!)
Using Enscape 3.1 the street (Bredgade) is in full sunlight at kl. 14:30 and full shadow at kl. 16:00.
Hi again. In the SetOneDay SunStudy you can only specify the GPS Location in Lattitude and Longitude (decimal degrees). You have no control of the timezone or weather DaylightSavingTime is active or not.
For now I would suggest to use first the Sun dialog with the longitude and latitude information you have, then see what the time is you get without daylight saving enabled. This will give you an idea of the time you get for your location. Adjust the input time for your animation based on your needs to account for daylight saving.
That said, I’m adding this thread to the bug report that already exists. The command should have an option for setting daylight saving: RH-62524 One day sun study time difference, just like the Rhino sun dialog already has.
