Another FilletSrf Challenge
FilletSrf isn’t yielding surfaces consistent with my objectives. larger radii produce “peakyer” surfaces?? is FilletSrf the correct tool for my objectives or should I be using something else??
inner bell.3dm (1.2 MB)
I’ve also explored using one of the Sweep commands but don’t see where I have enough of the required boundary conditions…
Art
Tried blendsrf? It has a bit of control
Pipe trim trick+blendsrf
FilletSrf gives you the shape that matches your magenta arc when you use the “arc” type option.
+1 for BlendSrf. Try selecting Tangency and adjusting the handles. Gave a reasonable result with little effort
Why would you try to approximate a fillet in multiple steps with BlendSrf, while you can get an exact fillet with FilletSrf?
Fair point, to which my answer was going to be “I wasn’t having any luck with FilletSrf, so settled for BlendSrf”
… That was until I noticed that the units were set to inches, and I was putting my Radius dimensions in as if they were in millimeters. Going from R1 to R0.035 actually gave a result
If you use an Arc fillet (G1) you get no “peaky surface”, but if you use a G2 fillet, then of course you do get a “peaky surface”.
Have you tried the “Same height” option of the “Blend surface” tool?
I used FilletSrf to demonstrate that if the tool is used correctly (Arc/G1 setting), the magenta curve, describing an arc fillet, can be achieved without any problem - no need to use a different tool.
a huge thanks to everyone who contributed! took me a while to recognize FilletSrf’s “Arc” switch and the fact it’s only G1. works slick if G1 is sufficient! in the end I resorted to a lofted solution that was a great deal of work but yielded a full material width radius and G2 or something very close depending on my accuracy… Thanks again for your ideas!!
Art
