here one of my most annoying bugs of the last years and I hope it’s reproduceable now. The problem is that often my mesh options are reset and my complex models are remeshed based on the wrong setup. It cost me a lot of time to get the setup back, since the meshing is quite slow.
I don’t know it’s important - I use a button script to go to the options: _DocumentPropertiesPage _Render
Here the steps:
open the attached file
( _DocumentPropertiesPage _Render -> only for info go to the mesh options, look at the settings (8/0/1/0/1/4) and cancel to leave the options) -
set backdrop from 360° to solid color and set black
close options
_DocumentPropertiesPage _Render and go to mesh options
The bug appears only if this way is gone. Don’t open the mesh options first and change the backdrop in a second step. This doesn’t show the bug.
I would be very glad if the bug could be catched.
Good luck,
Micha
Mesh-Option-Bug.zip (126.0 KB)
