[Annoyance] Rhino forced to the background when running commands with Grasshopper open!
I find it annoying when using Rhino and Grasshopper that you can’t repeat the Smooth or any other command that pops up a separate window in Rhino by hitting Enter a couple of times, since the Grasshopper window pops into the foreground after confirming the first command. You then need to click on the Rhino window, to be able to (re-)run any command.
This used to work in previous versions, something must have changed?
And yes, I know that for Smooth, you can set multiple smooth steps at once, but I often prefer to re-run commands!
I’m currently running Rhino 7 (7.10.21256.17002, 2021-09-13).
