Announcement! New and improved Grasshopper docs website
You mean in your personal gh they don’t show? Do you have the .gha in the correct folder called “Libraries” (not components, even though the menu path from gh is called components folder, it brings you to libraries) and have you unblocked it? It will also require that you fully close and re-open Rhino before using. I and many others use Pf for version 5, 6, and even WIP and it works. The errors for TBoxs usually occurs if any of the previously mentioned steps weren’t done. (I use Pufferfish also on a computer that doesn’t have Rhino 5 and it works)
Yes, shapediver took over squid.
Tree Sloth: https://www.food4rhino.com/app/treesloth
Or maybe it is there already because it’s components go into the regular Grasshopper tabs.
Yes, they work now. Maybe I should have installation instructions on the addon page. :slight_smile:
Newly added addons:
  • Chimpanzee
  • Bison
  • Slingshot
  • Clipper
  • Blindfold
  • Bubalus
  • Design Space Exploration
  • Droid
  • Flatworm
  • GeoDex
  • Gear
  • Impala
  • Instance Manager
  • KarambaIDEA
  • Mouse
  • Nemo
  • NM Optimisation
  • Opossum
  • Parakeet
  • Salamander
  • SkinDesigner
  • Tarsier
  • Telepathy
  • TRNLizard
  • WombatGH
  • Zebra
  • Sunflower
  • RoboDK
  • QuadEdgeDataStructure
  • Emu
  • KUKA Prc
  • RhinoMembrane
  • Tree Sloth
Nice!
thanks!
I’m seeing a “404 - There isn’t a GitHub Pages site here.” at http://rhino.github.io/. Am I interrupting an upload?
Hi Tim, the site has moved to www.grasshopperdocs.com
Thanks for that. I must have been viewing a cached version of this (Discourse) page; it redirects correctly now.
Is there a search function that I don’t see? If not, can one be implemented?
Edit: Never mind. It looks like I can go to the Complete Component Index and search there.
Hi @Robinicks, awesome work on the site! Sorry to resurrect an old topic (I don’t know if this discussion moved elsewhere), but would you mind featuring Assembler?
Thank you very much in advance!
Its done! Assembler - Addon for Grasshopper | Grasshopper Docs
Thank you!
However, it seems like several components are missing… :confused: (see the documentation page for reference Notion – The all-in-one workspace for your notes, tasks, wikis, and databases.)
Its fixed - Assembler - Addon for Grasshopper | Grasshopper Docs
Hi @Robinicks ,
You are doing terrific job with Grasshopperdocs website.
Thank you once again for all the effort and help you did for spreading information about Grasshopper plugins. Grasshopperdocs is truly a unique library!
Can we add the following 5 Gismo’s components:
Read Shapefile
Earth Anchor Point
Shapefile to location
Green View Index
Tree CO2
Thank you in advance for this addition.
Hi, yes I am working on a system that should fix this issue of missing components once and for all.
Thank you @Robinicks . That would be great.
Awesome! Thank you very much!
Hi @Robinicks, I noticed ShapeDiver is not part of the list anymore, although at some point we had made it work. Any chance to add the plugin again? Let me know if you need anything from our side.
Hi @Robinicks, I’ve just noticed that Assembler is categorized as a “Rhino addon”, while it is a Grasshopper plugin.
It’s not a major thing, but could you please correct that (no hurry)?
