File units is millimeters. Annotations are in meters and length dimensions are correct.
Area dimensions are displayed in millimeters unfortunately. Below is a screenshot from Rhino 8 on my PC.
Hi @martinsiegrist ,
Would you be able to send me that file so I can have a look?
24_01_02_annotation_unit_problem.3dm (125.3 KB)
Thanks
Thanks, I can reproduce the problem.
Formulas aren’t supported in iRhino at the moment. That’s what’s causing the issue here.
I logged a bug here
Ok, at least I know I haven’t done anything wrong.
Is there a quick way to convert formula based user text to static text?
Not that I know of, maybe @pascal has a script?
Hi Martin - this might work -
import Rhino
import System
def MakeStaticText():
filter = Rhino.DocObjects.ObjectType.Annotation
rc, objref = Rhino.Input.RhinoGet.GetOneObject("Select annotation", False, filter)
if rc != Rhino.Commands.Result.Success:
return
obj = objref.Object()
if not obj:
return
id = obj.Id
geo = obj.Geometry
text = geo.Text
if text is not None:
geo.RichText = text
obj.CommitChanges()
scriptcontext.doc.Views.Redraw()
if __name__ == "__main__":
MakeStaticText()
