Hi @Pascal,
i’ve found that i can change eg. the Model Space Scale of an annotation style, click OK and then use Undo to revert. But using Redo seems to do nothing in V6.
_
c.
Hi @Pascal,
_
c.
Hi Clement - thanks, I’ll check this.
@clement - Hm… this works here in my test at least. I can toggle back and forth with Undo-Redo, checking the style in between – the numbers change back and forth.
Hi @Pascal, hm very strange. If i now open the same file and do change model space scale setting it works (undo and redo)… I have no idea what caused it yesterday. Probably a friday problem…
_
c.
Yeah. Fridays are usually pretty ok, but once in a while…
