Annotation dot not displaying within clusters
Is it possible to enable it to be displayed from within the cluster?
I’m not seeing behavior that is different for the Annotation Dot component than for any other component.
unnamed (9.5.2025, 15.4.9) Edited v0.gh (35.5 KB)
You see here, if I go inside the cluster, I can not see the tags anymore.
I’m afraid that this video doesn’t tell me anything. I see a lot of fast zooming, panning, rotating, going on with the mouse cursor going all over the place. I have no idea what I’m supposed to be looking at.
When I open the cluster in your file and select the annotation dot component, the dots are highlighted in the Rhino viewport. What is wrong with that?
unnamed (9.5.2025, 15.4.9) Edited v1.gh (36.5 KB)
Thank you for your reply. I would like to say that when I place the Annotation Dot component within a cluster, I am unable to view the tags. On the other hand, if I place the Text Tag inside a cluster, I can view the tags of the Text Tag from outside the cluster.
Text entities are displayed but annotation dots not.
unnamed (9.5.2025, 15.4.9) Edited v0 text-entity.gh (35.5 KB)
But only sometimes?
wd_(9.5.2025, 15.4.9) Edited v0 text-entity.gh.gh (36.3 KB)
I’m not a fan of clusters…
It’s my first try so I don’t know what to expect (other than hearing about a lot of problems with them…).
You can get both if you make the dot an output of the cluster.
tag and dot.gh (5.3 KB)
That’s too easy :cat_with_tears_of_joy:
Hmm… so easy, :sob:Thank you very much!
This is a workaround and I don’t think this should be marked as solution.
The whole point of a cluster is to group a number of components as one single component.
Displaying things inside a cluster seems to be inconsistent and it would be nice if the developers could fix the problems.
