Bongo is able to animate material properties, including moving and rotating a texture.
If you animate the Offset value of a texture on a material, you can make the texture on the material rotate around the object.
The decal widget, Bongo is on the other hand not able to animate. So the texture you want to animate, you need to have it as a material texture.
