Animate (rotate) a spot light?
hello !
is it possible to animate a spot light ? i found it was possible to move a light, but i would like to rotate the spot and point it to different objects …
thank you !!
Yes, you can animate rotation on a spotlight the same way you can for any other object in Rhino.
Press the Animate button on the Timeline and then rotate the object into position with the BongoRotate command or by using the boxes on the Timeline.
