Angles to percentages, but different
He everybody!
I have a problem that I am not able to fix. I added a portion of my script to show what I need:
I need to convert angles to percentages but it is not like 0° = 0% or 360° = 100%. It is like this:
0° = 100%
90° = 0%
180° = 100%
270° = 0%
45° = 50%
I measure from the Y axis, but ofcourse, it is possible to measure from the X axis also if this makes more sense.
Somehow I cannot come up with the right equation and get it to work in grasshopper, if there is anybody who has a clue, don’t hesitate :slight_smile:
Stijn
angles to percentages.gh (14.1 KB)
modular.gh (8.4 KB)
Thank you for this qucik response! This seems to work, only not with 90° corners?
I think this is what I was looking for! thanks a lot
Ah, no when I use it in my script attached, it does not give the right output:
angles to percentages v02.gh (15.6 KB)
Haven’t integrated it into your script but this might help.
ANGLE.gh (9.0 KB)
angles to percentages v3.gh (16.9 KB)
Might one day it will end the life of this forum :sweat_smile:
Honeycam 2024-03-01 16-11-24
def angle_to_percentage(angle):
  """Converts an angle in degrees to a percentage between 0 and 100.
  Args:
      angle: The angle in degrees (0 to 359).
  Returns:
      The corresponding percentage (0 to 100).
  angle = angle % 360
  if angle < 90:
    return angle / 90 * 100
  elif angle < 180:
    return 100 - (angle - 90) / 90 * 100
  elif angle < 270:
    return (angle - 180) / 90 * 100
  else:
    return 100 - (angle - 270) / 90 * 100
a= angle_to_percentage(angle)
Using trigonometry, it could be solved like this:
angle_to_percentage_trigonometry.gh (19.3 KB)
Thanks to all the contribution! I think it’s working, doing the first tests with it.
I’m using it for a rotary axis 3d printer!
Stijn
