Angle between surface
I am trying to find the angle between two surfaces. Please see screenshot attached. I have created construction line so that i can find an angle between the two vectors but it is not giving me the right answer, so therefore i wondered if there is a way of finding angle between surfaces directly.
Can someone please assist.
Thanks
Post the code!
The angle between two planar surfaces is identical to the angle between their normal vectors. There’s a component for vector|vector angle, you just have to make sure that they both point in the right direction.
Origami Form.gh (61.0 KB)
Hi Joseph,
Code as attached. As you will notice the measuring angle between vector line solution will not work for the form created. Hope you can assist.
Thanks
Farjad
David’s answer is far simpler than anything I can offer.
Wow, that’s a lot of code! Took awhile to locate what might be the flaw? The blue lines connected to group “Theta Angle Between Two Planes” are not the angle between them, eh? Where the points are coming from that define those lines is even harder to trace. So I won’t. :sunglasses:
Later… confirmed; you have it, with a little math:
Origami_Form_2017Nov24a.gh (60.2 KB)
Simpler yet - green group:
Origami_Form_2017Nov24b.gh (60.5 KB)
Well advised to try David’s method for further confirmation and enlightenment.
Yes, its a quite detailed project hence the dense code.
How did I miss that! :frowning: I think I was over complicating things in my head.
Appreciate your help!! :slight_smile:
Regards
Farjad
