I’m trying to create an anemone loop to orient and rotate a line with a specific angle along a curve at every 5m interval. I’m getting stuck as the looping is not culling the used point along the 5m intervals.
Please see the reference image below. The orange curve is the 5m interval spine that i want to orient and rotate said line and a fix angle.
Would greatly appreciate any help please, thank you.
I assume there is going to be a difference in result because I have tweened on the basis of curve parameter, and you probably did this by sub-curve length.
Still does not match your result, so I have no idea how you are determining this. Certainly, the beginning and ending lines do not have the same orientation to the surface normals or the building contour does not have continuous curvature, and the ending frame belongs to another face of the building.
Bacause the bottom and the top has a specific orientation to the site and i just need to find the right rotation angle from floor2floor from 2 corner whislt having an open ended corners to later shape it.
It does. You can test this by taking two lines in a plane, creating a range of values in a 0 To 1 domain, and feeding these values into the factor input of the Tween component.
Then use the version that tweens the rotation factor.
You will not be able to satisfy the difference in angle between the starting and ending lines while remaining tangential to the surface at the intersection points of your seam curve on the surface at specific heights AND have a constant angle difference. That’s over constrained.
Yea, i agree, that’s why i was trying to ignore the ending lines and just trying to gain the angle control to reach as close as possible the end lines. Hence the script i’ve been tryin to develop.
Ah… That picture helps. I see the conflict. But no. If you want constant angle change between floors, this will dictate where the straight floor contour this touches the round and in turn the length of the straight edge.
You have alot of problem beyond this. Like the fact that your panel faces are not planar. The building will not be constructible like this with glass. Mostly, I’d like to know how you are coming up with the building shape in the first place. Do you have an algorithm? Is it in Grasshopper? Or have the floors slabs been imported from another source?
