I want to extract the final data from the anemone loop. Is there a way to do this? Thank you.
It’s the output on the loop end like any other component.
you can right click on the Loop End component and activate Record Data
in such a way it will output a list with all the computed iterations (this option works best -in my opinion- expecially if output after last
is also activated, but it depends on what you are trying to achieve)
