Hi, I’m having trouble getting certain anchor points along a rod to be recognized as goals. Sometimes this works and sometimes it doesn’t. I’m having a hard time recreating the working case. In the attached file, I have two examples that aren’t working.
The evaluated point at 0.4 needs to be part of the original curve. You either have to change 0.4 to a value so the evaluated point coincides with one of the vertices of the polyline within tolerance, find the closest polyline point from the evaluated point or raise the tolerance.
