Hi. I am thinking of building a steel tubular structure. I have the model in Rhino. The structure resembles EIERMANN 1 » RICHARD LAMPERT
Are there ways in Rhino to calculate if the structure will be wobbly or not ? I never done this so I appreciate if you can guide me, maybe a video, what type of plugin?
there are plugins like @karamba3d but the wobblyness will probably originate from the practical assembly and joints, less the load-bearing behavior of the steel tubes.
there are some rules in civil engineering how to ensure stability of houses:
at least three stiffening wall segments
walls in at least two nonparallel directions, usually the orthogonal X and Y directions
wall centerlines must not all intersect at one point, because that arrangement cannot adequately resist torsion
a sufficiently stiff floor diaphragm must transfer horizontal loads between the walls → this is the table top of your desk
yes, this works assuming everything is well connected (screwed, welded) and all 4 legs are the same length/floor is even. each side is basically a wall, the tabletop is the diaphragm.
