for some reasons this is just working for a simple curtain wall. if there is more devision, it gives an error: object refrence is not set to an instance of an object!
Hi Japhy, sure, you can see in the images, the wall which i created in GH, the HostGrids node to Deconstruct Curtain Grid works,
the second wall is the same fassade type of wall, but it has been created manually and the same HostGrids node to Deconstruct Curtain Grid does not work, it goes an error which i wrote above.
Hi @Japhy is this issue fixed? I am facing the same in my end. And meanwhile is there any way that we can export the curtain Grids from the host to rhino lines?
@Japhy Its also an issue to me too , would really like to see it being solve . Since it took me an hour to sort through 2000 curtainwall to find that was the problem with my previous script.
It doesn’t let any panels go through even if only one of them have a door on it . Can it at least work to let other panels to go through ?
