An interesting chair
I designed this chair that its seat and back seat is from the transparent and resilient plastic.
that’s the start of a cool image… play with camera length… try 35 mm instead of the 50 mm default.
also try a lower more dramatic angle… it’ll feel more like art and less like a cad model… :wink:
once you get a good angle and composition, mess with lighting…
try a single overhead panel light with a very low skylight value (like .01)
try changing the panel light to linear or inverse squared instead of constant… it makes the light a little more interesting…
Hello, sir
I have not worked with Keyshot except a little
I tried to change the light positions but I didn’t find any adjustment tool like what is in Rhino. Every type light of Rhino and also the position of sun can be changed but I didn’t find such the facilities in Keyshot.
It only has some limited and fixed options for light; such as " Basic, performance, interior or jewelry". These are some choices that are not adjustable. I couldn’t find light adjustments in keyshot similar to what is in Rhino.
Try using rhino render… I can help you with that. :slight_smile:
:slight_smile: I uninstalled keyshot and will go back to work with Rino render
