I used the GH_Document.ScheduleSolution Method to solve the problem, with reference to the following thread.
I’ve attached my code.
This code implements IGH_VariableParameterComponent, but it may work without it.
using System;
using System.Collections.Generic;
using Grasshopper.Kernel;
using Grasshopper.Kernel.Parameters;
using Rhino.Geometry;
using System.Drawing;
using Grasshopper;
namespace MyGrasshopperAssembly1.DynamicInput
public class DynamicInput02Component : GH_Component, IGH_VariableParameterComponent
/// <summary>
/// Initializes a new instance of the DynamicInput02Component class.
/// </summary>
public DynamicInput02Component()
: base("Dynamic Input 02", "DInp",
"Description",
"MyGHA", "Primitive")
VariableParameterMaintenance();
/// <summary>
/// Registers all the input parameters for this component.
/// </summary>
protected override void RegisterInputParams(GH_Component.GH_InputParamManager pManager)
pManager.AddGeometryParameter("Geometry", "G", "Input Geometry", GH_ParamAccess.item);
/// <summary>
/// Registers all the output parameters for this component.
/// </summary>
protected override void RegisterOutputParams(GH_Component.GH_OutputParamManager pManager)
pManager.AddGeometryParameter("Result", "R", "Result", GH_ParamAccess.item);
pManager.AddTextParameter("Info", "I", "Info", GH_ParamAccess.item);
private int faceCount = 0;
/// <summary>
/// This is the method that actually does the work.
/// </summary>
/// <param name="DA">The DA object is used to retrieve from inputs and store in outputs.</param>
protected override void SolveInstance(IGH_DataAccess DA)
try
var geo = new Brep();
if (!DA.GetData(0, ref geo)) return;
int newFaceCount = geo.Faces.Count;
if (newFaceCount != faceCount)
//faceCount = newFaceCount;
GH_Document gdoc = Instances.ActiveCanvas.Document;
gdoc.ScheduleSolution(0, CallBack);
else
List<Color> colors = new List<Color>();
for (int i = 0; i < faceCount; i++)
Color color = Color.White;
DA.GetData(i + 1, ref color); // Face count is 1-based
colors.Add(color);
DA.SetData(0, geo);
string result = "Received " + colors.Count + " colors.";
// color to strings
foreach (Color color in colors)
result += "\n" + color.ToString();
DA.SetData(1, result);
catch (Exception e)
AddRuntimeMessage(GH_RuntimeMessageLevel.Error, e.Message);
public void CallBack(GH_Document gH_Document)
//Variable Parameter Maintenance
// Remove all existing inputs
while (Params.Input.Count > 1)
var i = Params.Input.Count - 1;
Params.Input[i].Sources.Clear();
Params.UnregisterInputParameter(Params.Input[i]);
Params.OnParametersChanged();
// Add new inputs
// Create and add a new Input
var inp = new Param_Colour()
Name = "Color " + (i + 1),
NickName = "C" + (i + 1),
Description = "Color for face " + (i + 1),
Access = GH_ParamAccess.item,
Optional = true
Params.RegisterInputParam(inp);
this.ExpireSolution(true);
public override void AddedToDocument(GH_Document document)
base.AddedToDocument(document);
public bool CanInsertParameter(GH_ParameterSide side, int index)
return false;
public bool CanRemoveParameter(GH_ParameterSide side, int index)
return false;
public IGH_Param CreateParameter(GH_ParameterSide side, int index)
return new Param_GenericObject();
public bool DestroyParameter(GH_ParameterSide side, int index)
return true;
public void VariableParameterMaintenance()
//for (int i = 1; i < this.Params.Input.Count; i++)
// this.Params.Input[i].Name = (i - 1).ToString();
// this.Params.Input[i].NickName = (i - 1).ToString();
/// <summary>
/// Provides an Icon for the component.
/// </summary>
protected override System.Drawing.Bitmap Icon
get
//You can add image files to your project resources and access them like this:
// return Resources.IconForThisComponent;
return null;
/// <summary>
/// Gets the unique ID for this component. Do not change this ID after release.
/// </summary>
public override Guid ComponentGuid
get { return new Guid("CF6292BC-A312-425D-B51C-1D1897B73E52"); }
