I’m working on large make2D drawings. At the end, I need a 2D drawing made with closed curves or hatches for each surface.
It’s easy to select an entire drawing and make a CurveBoolean for all the regions or hatches for all the regions.
But then everything is in the same layer.
I wonder if there’s a solution for reselecting the closed curves or hatchings that are created with the make2D lines behind them. Because they are ordered by layers. Something like “select by touching or intersecting”? This would allow me to easily select the curves and dispatch them back to the correct layer.
In this direction I know the script made by @Helvetosaur in order to select intersecting curves, but I can only select a single curve at the start of the script, and not all the curves on a layer.
Or maybe there is another solution? By doing directly the CurveBoolean or Hatch command and keep the layer?
I hope I am understanding.
Thanks for your help,
Benoit
