I am wondering if there’s a way to create a macro that I would attach to an alias that would change the distance display in Options/ Document Properties/ Units from Fractional to Feet & Inches and back?
If this is doable, can one change the display precision as well?
All those options should be reachable with a macro. Start with the -DocumentProperties (note the dash) command and read the command line to get to the option that you need. Then just put the letters you need to get there into your macro.
