The .amf format (Additive Manufacturing File Format) supports objects consisting of multiple volumes with optional metadata, for example slicing parameters or material information for each volume. Is it possible to create such an object / volume hierachy with Rhino? I want to create something like in the example pictures below:
The .amf used in the examples was created with the online insole creation tool at http://gensole.com/.insole (2).amf (1.3 MB)
So far, I managed to export multiple grouped objects (that overlap partially) as a single .amf, but in the resulting XML-File there are always multiple objects defined, not a single object consisting of multiple volumes. To clearify my question:
- How do I create a multi volume object for .amf-export in Rhino?
- How can I define metadata for each volume in the object?
My final goal is to create objects with sub-volumes that define different infill-settings for slicing.
I look forward to any tips and suggestions
