@bisenberger, only a dev who wrote the integration can help you i guess. I have the Beta but it is installed in the Wip folder. My SystemInfo almost has the same for graphics as yours posted above. One difference is i’m on Win7x64 and it lists only 128Mb of Ram.
I installed the HD7970 in a different computer running Work In Progress (6.0.17304.10081, 10/31/2017) Beta. I let Windows 10 Pro automatically install the AMD drivers. It installed Radeon Software Version 17.1.1. ProRender successfully installed on this setup, but keeps crashing.
The 7970 does date to 2011, does it actually support the right version of OpenCl to run ProRender? And if it did could you reasonably expect it to be useful?
The Rhino WIP installed the update to BETA (6.0.17311.8431, 11/7/2017) Beta and fixed much of the crashing.
Hi JimCarruthers,
Current OpenCL version installed 22.19.162.4. The ProRender in Blender works very good and I’m confident McNeel will get ProRender up to speed in Rhino. The OpenCL performance with Photoscan is also very good.
ProRender is pretty quick, but it does strange stuff to texture mapping and some textures. Here’s an image that shows the difference between how the texture mapping looks in a Rhino Rendered viewport compared to a ProRender viewport.
I can confirm this as mentioned above. Messing with the texture repeat values seems to set integers to floats and the default mapping looks wrong. I wonder if this has something to do with our display cards which are identical.
Hm, mp4 works over here when played with windows media player. (10 years old) but not in FF.
I’ve tried to upload the video now 4 times, *.avi is not accepted, *.mp4 (converted from avi using h264 and VLC cannot be played, when i zip the *.mp4, filesize 5Mb and drag it over the message window it shows the upload progress till 99% then nothing.)
Yes, the circles have been caused by the groundplane. Good you’re now seeing that textures don’t work. I’ve found more bugs in ProRender importing larger files without using any textures. It seems all my geometry looks like having triangular faceting effect in variing grayscales which occassionally vanishes if i zoom very close to the object.
Thanks for all the feedback. I am currently working on building ProRender with the latest toolkit. After that I will look into your bug reports and wishes.
Is there some news about new version of ProRender? I’m using latest Rhino 6 Beta (Release Candidate 2), and I’m unable to load this plugin, because of error message “Dependent DLL is out of date.” Unfortunately I don’t know, which DLL is in question here. Can somebody here guide me, which log can contain detail information about this error message?
Hello Nathan.
Yes, I did download RadeonProRenderRhinoPlugin_20171106.rhi, and also re-download it, just to be sure, that downloaded file isn’t corrupted. Unfortunately, no change, still same error message. I also checked, if I have a latest Rhino 6 Beta version, and this is true as well.
