AMD denoiser not working
AMD denoiser doesn’t work on my MacBook Pro 16" with AMD 5500m GPU.
I’m using v7 WIP and running Big Sur.
It comes up with this error.
Logged as RH-61648 AMD Denoiser not working on Mac.
@robinp if you could run the Rhino command _SystemInfo and paste the results here.
Rhino 7 SR0 2020-11-4 (Rhino 7 BETA, 7.0.20309.06004, Git hash:master @ 368ab021c8426434a95c36999f545f918e04df2c)
License type: Commercial, build 2020-11-04
License details: Cloud Zoo
Expires on: 2020-12-19
Apple Intel 64-bit macOS Version 10.16 (Build 20B29) (Physical RAM: 64Gb)
Mac Model Identifier: MacBookPro16,1
Language: en-GB (MacOS default)
AMD Radeon Pro 5500M OpenGL Engine (OpenGL ver:4.1 ATI-4.0.47)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 4 GB
Graphics: AMD Radeon Pro 5500M
Displays: Color LCD (264dpi 2x), DELL U2715H (109dpi 1x)
Graphics processors
Intel UHD Graphics 630 (1536 MB)
AMD Radeon Pro 5500M (4 GB)
Color LCD (1792 x 1120 @ 59Hz)
DELL U2715H (2560 x 1440 @ 59Hz)
USB devices
CalDigit: Card Reader
Seagate: Expansion
CalDigit, Inc.: CalDigit Thunderbolt 3 Audio
Realtek: USB 10/100/1000 LAN
Apple Inc.: iPhone
Apple: composite_device
Apple Inc.: Touch Bar Backlight
Apple Inc.: Touch Bar Display
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple: Headset
Apple Inc.: Ambient Light Sensor
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Apple T2 Controller
Bluetooth devices
Nordic Semiconductor:
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreData.dylib
/usr/lib/swift/libswiftFoundation.dylib
/Users/robinphillips/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/bella_rhino.rhp/libbella_dotnet_native.dylib
/Users/robinphillips/Library/Application Support/McNeel/Rhinoceros/packages/7.0/IntelDenoiser/0.6.0/libtbb.dylib
/Users/robinphillips/Library/Application Support/McNeel/Rhinoceros/packages/7.0/IntelDenoiser/0.6.0/libtbbmalloc.dylib
/Users/robinphillips/Library/Application Support/McNeel/Rhinoceros/packages/7.0/IntelDenoiser/0.6.0/libOpenImageDenoise.1.2.3.dylib
/Users/robinphillips/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/bella_rhino.rhp “Bella” 20.7.0.0
/Users/robinphillips/Library/Application Support/McNeel/Rhinoceros/packages/7.0/raytraced-materials/0.1.3+v6.15/RaytracedMaterials.rhp “Raytraced Materials” 0.1.3.0
/Users/robinphillips/Library/Application Support/McNeel/Rhinoceros/packages/7.0/raytraced-blend-material/1.3.0/RaytracedBlendMaterial.rhp “RaytracedBlendMaterial” 1.3.0.0
/Users/robinphillips/Library/Application Support/McNeel/Rhinoceros/packages/7.0/AMDDenoiser/0.4.1/AMDDenoiser.Mac.rhp “AMDDenoiser.Mac” 1.0.0.0
/Users/robinphillips/Library/Application Support/McNeel/Rhinoceros/packages/7.0/IntelDenoiser/0.6.0/IntelDenoiser.Mac.rhp “IntelDenoiser.Mac” 1.0.0.0
/Applications/RhinoWIP.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.0.20309.1002
/Applications/RhinoWIP.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.0.20309.1002
/Applications/RhinoWIP.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 7.0.20309.1002
/Applications/RhinoWIP.app/Contents/PlugIns/SolidTools.rhp “SolidTools” 7.0.20309.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.0.20309.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.0.20309.1002
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.0.20309.1002
/Applications/RhinoWIP.app/Contents/PlugIns/MeshTools.rhp “MeshTools” 7.0.20309.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.0.20309.6004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 7.0.20309.6004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 7.0.20309.6004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 7.0.20309.6004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 7.0.20309.6004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.0.20309.6004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 7.0.20309.6004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 7.0.20309.6004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 7.0.20309.6004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 7.0.20309.6004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 7.0.20309.6004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 7.0.20309.6004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 7.0.20309.6004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 7.0.20309.6004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.0.20309.6004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 7.0.20309.6004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 7.0.20309.6004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 7.0.20309.6004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.0.20309.6004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.0.20309.6004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.0.20309.6004
Hi @robinp,
Just want you to know that we’re looking into this.
-David
Hi David
I’m having a total crash with the Flamingo renderer when I try to engage the AMD Denoiser (clicking the selection box). My system is totally different from rbinp’s so there seems to be something seriously wrong under the hood:
Rhino 7 SR3 2021-2-22 (Rhino 7, 7.3.21053.23031, Git hash:master @ f8a40388712d9cf7edc68910e0415427bdefc64a)
License type: Kommerziell, Build 2021-02-22
Windows 10.0.18363 SR0.0 or greater (Physical RAM: 16Gb)
Computer platform: DESKTOP
Primary display and OpenGL: AMD Radeon ™ R9 200 Series (AMD) Memory: 2GB, Driver date: 11-13-2020 (M-D-Y). OpenGL Ver: 4.6.14757 Compatibility Profile Context 20.11.2 27.20.14501.18003
> Accelerated graphics device with 8 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Shading Language: 4.60
Driver Date: 11-13-2020
Driver Version: 27.20.14501.18003
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\Flamingo nXt 5.0 (fd53f8c4-546d-47d1-8820-e66c97645a97)\5.5.18347.11581\5.5\Flamingo.nXt.rhp “Flamingo nXt 5.5” 5.5.18347.11581
C:\Users\Andreas\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\AMDDenoiser\0.4.1\AMDDenoiser.Windows.rhp “AMDDenoiser.Windows” 0.4.1.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.3.21053.23031
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.3.21053.23031
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.3.21053.23031
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.3.21053.23031
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.3.21053.23031
Since there is no further reply to robin’s post it seems there is no answer yet. So I’ll add my bug to the list.
Andrew
Does it work better if you use the Intel denoiser instead?
Yes, that works.
Ok, I think your GPU is too old for the AMD denoiser to work properly. Maybe a driver update may help, but if the Intel denoiser works for you I’d stick to that.
Thanks for the tip.
As you indicated the graphics card is probably “too old” since I’m current on all my drivers on the stable releases. I doubt that AMD will or even can jack it up to the newer requirements of openCL and openGL.
Hi @andrew_klemm,
I would like to know if the AMD denoiser is still working badly for you. Could you get the latest Rhino 7 version + latest AMD denoiser and do another test?
Thanks,
-David
Hi David
Tried the scene again and the denoiser seems to work fine. I did change a few things: I’ve installed a new graphics card (AMD Radeon WX5100), cleaned the CPU cooler and have the most current version of Rhino.
Regards
Andrew
