hi there, is there a way to have the point coordinates displayed permanently while working and not have to run evaluatept all the time ? I have assigned it to a keyboardshortcut now but it would be easier if i could just always have it displayed so it doesn’t go into the command history which i always use to trigger the last command.
Hello - I do not have my mac available at the moment but I think you can set up cursor tooltips as in Rhino for windows in Preferences > Modeling aids.
If it is point object coordinates, not just a location, you can set particular points to have a label using text fileds:
You can add any command to
Never repeat these commands
List.
that’s great thx!
so when i enable the cursor tooltips nothing happens, i can’t see any tootltips.
that sounds like exactly what i need but i can’t find this feature, where do i get that Text Field dialog box ?
Hi Chris -
You will only see those when you are placing a point, inside a running command.
hey thx everyone for your tips … doesn’t really sort my problem thou, i was just thinking there was maybe a properties tab or some way to display coordinates like the cursor coordinates.
but with the shortcut key and removing evaluatept from the repeat commands that works for now.
just weird that there isn’t a status display for selected objects when there is one for the cursor.
the
BoxEdit
panel
unfortunately that doesn’t work on points, ctrl points or vertices, only for objects.
