Always pan parallel views turns itself on
I am having an issue with Rhino 8 Beta. the “always pan parallel views” sometimes turns itself on when I’m switching between views. Usually going in to the setting menu and unchecking the box turns it off again but not always. In which case I have to close and reopen Rhino 8
Hi Sam -
Please run the Rhino SystemInfo command and copy-paste the result here.
Rhino 8 SR0 2023-10-24 (Rhino 8 BETA, 8.0.23297.13304, Git hash:master @ 4368ce4c82870d4ce7b0ef004198da23d48ffe5f)
License type: Commercial, build 2023-10-24
License details: Cloud Zoo
Expires on: 2023-12-08
Apple macOS Version 13.6 (Build 22G120) (Physical RAM: 32Gb)
Mac Model Identifier: MacBookPro18,2
Language: en-GB (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M1 Max
Color LCD (1728 x 1117 @ 120.00Hz)
USB devices
None
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
/usr/lib/usd/libIex.dylib
/usr/lib/usd/libHalf.dylib
/usr/lib/usd/libAlembic.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/usd/libosdCPU.dylib
/usr/lib/usd/libImath.dylib
/usr/lib/usd/libIlmThread.dylib
/usr/lib/usd/libIexMath.dylib
/usr/lib/usd/libtbb.dylib
/usr/lib/usd/libMaterialXCore.dylib
/usr/lib/usd/libMaterialXFormat.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/usr/lib/swift/libswiftExtensionFoundation.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftExtensionKit.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMapKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/Applications/RhinoBETA.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.0.23297.1002
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.0.23297.13304
/Applications/RhinoBETA.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.0.23297.1002
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.0.23297.13304
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.0.23297.13304
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.0.23297.13304
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 8.0.23297.13304
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 8.0.23297.13304
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.0.23297.13304
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.0.23297.13304
/Applications/RhinoBETA.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 8.0.23297.1002
/Applications/RhinoBETA.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.0.23297.1002
/Applications/RhinoBETA.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.0.23297.1002
/Applications/RhinoBETA.app/Contents/PlugIns/RhinoLabsTools.rhp “Rhino Labs Tools” 8.0.23297.1002
/Applications/RhinoBETA.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.0.23297.1002
/Applications/RhinoBETA.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.0.23297.1002
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.0.23297.13304
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.0.23297.13304
Do you use the Auto CPlane?
Yes. Does this conflict with orbiting in parallel?
The Auto CPlane automatically turns that on when you select something in a parallel view and turns back off when the CPlane returns to the original orientation. This is so when you right click and drag the view doesn’t rotate and instead pans. It’s supposed to make using the Auto CPlane in plan views easier. The issue is here and I implemented that behavior awhile ago. I don’t know if it’s working right and just confusing you or if there’s a bug you found.
Ah okay. Makes sense. I’ll keep playing with it.
