What are some alternatives to Curve.GetSubCurves? This call ties my plugin to version 8.13 while I would prefer it to be available for earlier versions as well. I am using it to ubiquitously convert curves even if they are polycurves.
from the documentation:
The results will be similar to what is produced by Rhino's **Explode** command.
That’s great but this method exists in the PolyCurve
class while I would like to use it for the general Curve
class. Would it be sufficient to create this extension method myself or can there be corner cases where any kind of curve that consists of >1 segments would not be handled?
public static Curve[] getSubCurves(this Curve curve) {
if (curve is PolyCurve polyCurve) {
return polyCurve.Explode();
else return new Curve[] { curve };
Hi @dale ,
This is also what the documentation claims, however if I reference any version of RhinoCommon
before 8.08, I get an error message. So I am looking for an alternative.
Yes, I can see that. There is the original issue.
https://mcneel.myjetbrains.com/youtrack/issue/RH-81979
So why would you want support versions older than 8.8? If you find a user with an older version, they should be encouraged to update.
– Dale
