Alt+drag can't copy component identically?
PixPin_2025-02-28_19-54-07
Hi Developer,
this is nothing important,but why alt+drag can’t copy component identically ?
Thanks for your feedback, I will log it to our development engineer.
You can fix this issue via toggle the option Draw Full Names under the Display of menu.
There are so many components with this problem.
Thanks for your attention to this. Another instance similarly:
PixPin_2025-03-02_04-00-13
Also Entwine and Merge revert to shorthand from full name display as soon as the number of inputs change.
Yes.
PixPin_2025-03-02_04-19-16
PixPin_2025-03-02_04-23-35
Explode Tree… the list goes on.
You are right.
PixPin_2025-03-02_04-27-20
It goes like this for every component that has input or output where you can add/remove elements with ZUI.
I don’t see why this is a problem but I’m curious, what are the scenarios where this could be a problem?
Functionally there is no problem.it is hoped that Grasshopper could to be “prefect” In terms of consistency.
