Wim’s suggestion to use Alt and 0178 works for me however, when I print to PDF the superscript changes to another character - in this case the “less than or equal to” sign. See images below. Any suggestions on how to fix this?
Windows 10.0.0 SR0.0 or greater (Physical RAM: 64Gb)
Machine name: ######-WS01-N
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2080 SUPER (NVidia) Memory: 8GB, Driver date: 11-20-2019 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 441.41
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-20-2019
Driver Version: 26.21.14.4141
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
Seems to be present with all drivers. I’m not connected to a printer right now but even when I select my usual printer, in the Rhino print preview the issue is still there.
The print preview doesn’t use the drivers to generate a preview and may not reflect what the driver actually produces. You would have to test a few outputs to see if you get different PDFs. Try Rhino PDF if you haven’t already.
For all of the PDF drivers I did actually test print to a PDF file - still had the issue. I can’t test on the physical printers as they are at the office and well COVID…
