ALT and right mouse button. (Rhino8)
Hello! I’m worried, has the version update changed the mouse settings or is there a problem elsewhere? I’m studying Level 1 and the assignment required me to copy a cone without the help of a gumball. The ALT and right mouse button combination doesn’t work.
Sincerely, Kaupo
while dragging, you have to briefly tap the Alt key, not hold it. Holding it toggles Osnaps.
Hello!
Thanks, I finally got it working, the problem is that sometimes it doesn’t display the dot, then it doesn’t work, but if you move the mouse over the lines, the dot appears and then it activates.
Thank you!
