I have a problem with my Alpha channel in Rhino 7. It shows only the curves instead of the solid objects as visible on the screen shots below.
It only happens if I work on a 4k monitor.
When I lower the resolution of the monitor to standard 1,920x1,080 it solves this issue.
Has anyone solution for this problem?
