Hi
I have a small problem, I’m trying to make a shape like this:
I’m using extrude curve -> along curve command, and at the end of the curve the shape gets very thin:
what am i doing wrong?
Hi
Extruded along curve keeps the cross-sections parallel. You need to use Sweep1 instead.
Regards
Jeremy
Hello
Did you try to use _sweep1 command instead of using _alongCurve command ?
Dan
works well, thx!
