I am working on the last two major areas of my steam tractor model that need detailing. I just finished adding the towing cable to the model. The towing cable consists of a drum that the cable is wrapped around and a pair of rollers that guide the cable from the drum to whatever needs towing.
I started out using the Pipe command, with the cable centerline I created, planning on using a PBR texture to create the look I was after. I found a decent looking wire texture, downloaded it and applied it to the pipe. It did not look good no matter how much I tried.
This is not a critique of the texture, not at all. It just didn’t work way way I wanted it too. So I built a new 7 strand cable using 7 pipes, a center pipe and six more pipes wrapped around the center one.I laid out a line the same length of the cable and wrapped a helix around it. This allowed me to adjust the number of turns until I found a number that looked good. I then used a Circle Array to get a set of six helix’s. I used flow Along Curve to wrap the helix center lines around the cable center line.
I found a cable strand diameter calculator on line that was useful in finding the diameter of the individual strands for the strand layout I used.
I used Pipe on the center curve and the helix’s which gave me the results I was looking for.
The cable crimp block, thimble and shackle were made from drawings I downloaded from the McMaster Carr website, no solid parts were available.
My last project will be filling up the coal bin with coal. I downloaded Blender and plan on using its rock generator plug-in to make the coal pieces.
Chris Holtorf
