This is something new, after today’s update:
You can see the text is there
but it is gone when zoomed in
Have you been doing anything to the text display pipeline recently?
Hi Piotr -
I’m not seeing that here. Can you reproduce that in a new file from a factory-default template using the fonts and styles without modifications?
Also, please provide the SystemInfo
data.
There is something going on here, for sure.
New file from template, default text settings:
Could you post your SystemInfo
-w
Rhino 8 SR0 2022-4-19 (Rhino WIP, 8.0.22109.08305, Git hash:master @ 411144bf79a8d3f9172096d5e6bd59ccd416f32f)
License type: Commercial, build 2022-04-19
License details: Cloud Zoo
Expires on: 2022-06-03
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 16Gb)
Computer platform: LAPTOP - Plugged in [98% battery remaining]
Primary display and OpenGL: Radeon Pro 560X (AMD) Memory: 4GB, Driver date: 11-11-2021 (M-D-Y). OpenGL Ver: 1.1.0
> Integrated accelerated graphics device with 7 adapter port(s)
OpenGL Settings
Safe mode: Off
Use accelerated hardware modes: Off
Graphics level being used: OpenGL 1.1 (software driver)
Anti-alias mode: None
Mip Map Filtering: Linear
Vendor Name: Microsoft Corporation
Render version: 0.0
Shading Language: Not supported
Driver Date: NA
Driver Version: NA
Maximum Texture size: 1024 x 1024
Z-Buffer depth: 32 bits
Total Video Memory: 64 MB
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\CreateQuadMesh (5bf6c0f3-3657-4ad5-834a-bbbb52706a40)\6.0.6914.24116\CreateQuadMesh.rhp “CreateQuadMesh” 6.0.6914.24116
C:\Users\Piotr\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Grasshopper2\2.0.8132-wip.36848\Grasshopper2Plugin.rhp “Grasshopper2” 2.0.8132.36848
C:\Program Files\Rhino 8 WIP\Plug-ins\Commands.rhp “Commands” 8.0.22109.8305
C:\Program Files\Rhino 8 WIP\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.0.22109.8305
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.0.22109.8305
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
C:\Program Files\Rhino 8 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 8 WIP\Plug-ins\Constraints.rhp “Constraints”
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.0.22109.8305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoRoslyn.rhp “RhinoRoslyn” 8.0.22109.8305
C:\Program Files\Rhino 8 WIP\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.0.22109.8305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.0.22109.8305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoCPython.rhp “RhinoCPython” 8.0.22109.8305
C:\Program Files\Rhino 8 WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.0.22109.8305
C:\Program Files\Rhino 8 WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 8 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 8 WIP\Plug-ins\ConstraintsUI.rhp “Constraints UI” 8.0.22109.8305
C:\Program Files\Rhino 8 WIP\Plug-ins\Calc.rhp “Calc”
Thanks, Piotr -
Your GPU drivers somehow got messed up. You should probably do a clean install of the newest drivers to get this on the road again.
Hi Wim
I have done the factory reset again.
It doesn’t help. Strangely, the objects with Sun looks darker than without it.
Meanwhile V7 works as expected and is recognising all video card capabilities.
Hi Piotr -
I’m not sure if I’m understanding that correctly. When you run SystemInfo
in Rhino 8, is it giving you a different result than when you run it in Rhino 7?
Strange.
A minute ago, when I was writing the report to you I couldn’t see any text and I couldn’t set antialiasing.
Suddenly it started working again and I have done nothing to make it work (not restarting or creating new file).
There is another small issue:
There is a seam visible but tangents are off.
Thanks, Piotr. I threw that on the list as RH-68364.
