I’ve been testing va on RHino 8, but if it’s installed blocks disappear when selected.
So I’m back on 7 but - after round tripping project to Rhino 8 from Rhino 7 and back - my project’s sections have turned into generic non-functioning blocks, and all levels and some styles are missing.
I think I can get them back by importing settings and maybe a RUI file from a previous project, but I’m not sure how to go about it, so any advice welcome, thanks. They are still in my current template file.
If you have a copy of the file where levels and styles are missing, it will be useful.
If you have VisualARQ 3 installed in both Rhino 7 and Rhino 8, saving a file in Rhino 8 as a Rhino 7 file should open fine in Rhino 7, also if it includes VisualARQ objects. If those are recognized as block instances, or the levels are missing, it may happen because VisualARQ is not loaded in that Rhino session. But if you don’t edit these blocks, they should be recognized back as VisualARQ objects as soon as VisualARQ is loaded properly.
This seems to indicate (and it’s likely) that I saved the Rhino 7 projects from Rhino 8 projects which had Va disabled. Those of these projects subsequently opened in Rhino 7 (with Va enabled) are missing almost all object styles from the Va style editors. The only Va objects in use in these projects (both R7 and R8) are sections, which in the R7 versions have become blocks with no functionality or association with Va. Would it be helpful for me to upload one of these files? R7, R8, or both?
Ok thanks, that’s good to know. Can you tell me how I can get my styles back into those projects from previously saved R7 versions of the same projects, which will be the same.
@djhg The file you saved from Rhino 8 as a Rhino 7 file with VisualARQ disabled has data that Rhino 7 can’t read. If you save that file in Rhino 7 the VisualARQ data will be lost.
If you don’t save it, you will recover the VisualARQ data of that file if you open it again in Rhino 8 (with VisualARQ enabled, of course).
