@Nosaj one other thing, was this a nested block? And if so, which level were you making edits in?
I think it was ZSA,but i can’t really remember,which is probably not very helpful.
It wasn’t a nested block.
I can send you the file if you want.
yes that would be helpful. I will try to stress test it, hopefully finding a reliable way to reproduce it.
You can send it here, to my attention, thanks
i meant the broken file.
That might also be helpful
Hi @Gijs ,
I have a file with the same problem in a saved state where you can close the block editor and everything disappears.
I am trying to send the file but it won’t upload for smoe reason,It’s in 7z format.
@Nosaj there seem some problems with that server at the moment, maybe you can wetransfer it and send the link to me in a pm? Sorry for the inconvenience.
Yes this has just happened to me! while editing a newly copied layout from a1 to a3 it disappeared and then the original disappeared too.
Weirdly when i print the layouts to pdf they print, but i cant edit them as there is nothing visible.
Hi @Sam_Johnston
Can you send the file? If too large or confidential you can send it in a pm or to Rhino Accounts
Pls also run _SystemInfo and post back the results.
sam-systeminfo.txt (5.0 KB)
I hope this is what you were looking for.
Cheers,
Sam
Ive sent a dm with a link to the file.
replied in pm, this looks to be a different issue.
Thanks Gijs, Appeciate your help. It seems to be fixed now but I cant understand how it happened? something in the copylayout command or the edit page size?
Anyway thanks again.
Sam
