AlignProfiles (command in sdk)
hi @dale
have a nice day
What is RhinoCommon(API) AlignProfiles {command in Rhino}recipe?
I need to it, but can’t I find the order?
Also API For Curve from cross section profiles
Hi @architect.civil5,
There is no single, RhinoCommon method that does the equivalent of the AlignProfiles command. But there is an sample of how the command works:
SampleCsAlignProfiles.cs
Where do you see this in Rhino?
Thanks,
– Dale
I assume he means this:
i.e. the CSec command.
Yes it Csec command
Sure, of course.
If I recall correctly, the CSec command creates a plane from the cross section line point and then intersects the curves with that plane. The intersection are then used to create a cubic NURBS curve. Curve.CreateInterpolatedCurve should work for this.
– Dale
Thanks
