I have a planar curve that I extracted from a polysurface, I’m working on a template where the polysurface had to be moved at an odd angle for it’s application. The curve is closed, and I’d like to re-align the gumball to 90 degrees to the plane of the curve so I can re-extrude the shape and make it longer and remove some reference marks from the surface.
This is an area that I’ve not had much experience with, so any help would be appreciated.
Thank You
-Paul-
