Hi Every one.
Do you know if there are some command or script to align multiple points surface on a polyline like tsmatch
t-spline
Thanks
Hi Every one.
t-spline
Thanks
I don’t have much experience myself with T Splines … but from your description, and the name of the T Splines command mentioned, maybe _MatchSrf is what you are looking for?
http://docs.mcneel.com/rhino/5/help/en-us/index.htm#commands/matchsrf.htm
If not… can you maybe share an example of what you want to achieve?
Hi Rodri
thank you for your reply
I attached an example who I want to achieve
I would like to align surface control point on the polyline in one click
besically i would like to use the polyline as a reference
Thanks
Hi Federico - it is not one click but you can do it:
CurveThroughPt
> CurveType=Interpolated.Flow
from the curve you made to the target curve, Stretch=Yes, probably.-Pascal
Thank you pascal
@Federico_Fenoglio1 - here’s a macro to use to speed things up a bit -
! _CurveThroughPt _Degree=3 _CurveType=_Interpolated Closed=_No _Enter _Flow _Copy=_No
Use this with the points selected. There is a curve to clean up when done. I guess it may be possible to take care of this in the macro as well.
