Align points into closed curves
I’m trying to align curves within other curves, as if templates to correct (the inside ones) for possible misalignments (regarding the template). I think it’s may be simple to solve, but I have stuck in the reconstruction of internal polylines.
Move points inside the radius to template point:
I’m also wondering how to align the other points that is just near by template line (not inside radius) and align them to the line borders:
Any help or tips would be great!
Thanks so much!
(Thanks for everybody you guys help us so much :slight_smile: )
Align Points.gh (8.5 KB)
Align Points.3dm (54.4 KB)
you could use (for a shortcut) MoveToPoint from pufferfish plug-in - grab all things you want to move, specify their point(s) to move from and the point(s) to move to - if not then you have some work-around options like (simply) move along the vector length between two points (the one to move from and the one to move to)
try with closest point.
Align Points_ev.gh (13.6 KB)
