Align object along a plane
align object along a plane.3dm (108.7 KB)
Does anyone know a direct command to align or project a volume tube onto a plane surface? I have attached the file in this post.
Dear @j.woo
your geometry is fare away from world origin - this will cause problems.
your document tolerance is 0.01 and the chamfer has the same size - this will cause more problems.
check the following commands to orient objects on a surface or a construction plane:
_orientOnSrf
_remapCplane
and many more here V6
http://docs.mcneel.com/rhino/6/help/en-us/index.htm#seealso/sak_transform.htm
V7
http://docs.mcneel.com/rhino/7/help/en-us/index.htm#seealso/sak_transform.htm
kind regards -tom
