Align normals to nonplanar curvature
Hi all,
I want to alight the normal of the Divide Surface to match the curvature generated by the Tween component, I am not sure how to do it but aligning the plane was what I thought could be the approach, can anyone help me figure this out?
Plane adjustment.gh (15.3 KB)
Thanks.
I’d like to know if this is what you want?
Hi Jesse, almost.
I want it to be flat on XY, at the moment the plane is vertical.
This is how the curvature warps as more layers are added:
And I want the Normals to warp with the curvature:
So it will point more inwards the more it warps.
So perhaps the plane could look like this, because the normal has warped with the curvature.
I hope this makes sense.
Thank you.
Perpendicular frame is surely what you need, if you want other orientation, just deconstruct plane then reconstruct it if necessary, normal is Y or -Y, you can orient it (using Z of XY plane)
Z =cross(X, Y)
And some play at the bottom of the file
Plane adjustment_LD.gh (31.4 KB)
Hi Laurent, thank you for this, I think the solution is somewhere there but I am lost with the additions you have included, let me explain perhaps better hopefully it will be easier for you to guide me with this, I want the vectors to be pointing the way you have done, just like this:
Plane adjustment.gh (12.2 KB)
But instead of using a curve I want this to be done to the curve divided by points, I want the vectors of all the points to be doing this, at the moment it is one point on every layer, because perp frame takes a curve instead of points.
The point of this is because I am writing a GCode for a robot arm to print in multi-axis, and the Gcode must be a series of points.
Thank you.
@jessesn gave you the solution, but multiple perpandicular frame gives the same answer.
Plane adjustment (1).gh (14.3 KB)
Yes, thats right, thanks Laurent.
