Align gumball to a group of objects
Is there any way to align gumball to a group ?
Hi Rachel - Gumball cannot be remembered for a multiple selection, which is what a group is, I’m afraid. Gumball can be aligned using RelocateGumball BUT it will not stick - it can only be used once; if you de-select the group it will be lost. A possible workaround is to Block the objects rather than group, then the block instance acts as a single object.
Hi Pascal, thank you very much for your help :slight_smile:!!
