Align Curves
is there a way to align ? (seam & direction)
besides parakeet component
(for PC’s w/t parakeet, school labs etc.,)
align
First align the seams with the Seam component. You can find the seams by using closest point component (although in some cases it will have issues because you can’t do it iteratively like you can with a script or the Pufferfish Align Curve Seams component). Then use the flip curve component with one of the curves as a guide to adjust all the directions.
yep I see your point ! gonna check out the Pufferfish Align component.
thnx!
I can’t use the Pufferfish Align Curve Seams component. Could you give a small example?
Check the examples files. There is an example for every component.
