Align curve handles
thought I saw in a turtorial a way to align contol points on curves (maybe it was mesh points), like as if you turned on points then used the align command and select the points you want (that part doesnt work). I did see posts about using align grips macro… Is that the only way besides selecting each line and dragging the point with snapping to a neighboring elevation point?
points%20align%20question
Hi @Synergy,
You can align your construction plane to the curves in question if not already aligned and use the magical _SetPt Command on all points at once
that was it, I tried it before but didn’t play enough to get it set to align to cp plane…! so it worked thank you.
