I have aliasing when i make view without blur for shadows
Hi Henry -
Please provide both the output of the Rhino SystemInfo
command and a 3dm file that illustrates the issue.
Rhino 8 SR11 2024-9-10 (Rhino 8, 8.11.24254.15001, Git hash:master @ d3c11108eae09fadc146928ba51b9b182a05303f)
License type: Commercial, version 2024-09-10
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.0
Computer platform: LAPTOP - Plugged in [29% battery remaining]
Primary display and OpenGL: NVIDIA GeForce GTX 1660 Ti (NVidia) Memory: 6GB, Driver date: 1-18-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.23
Primary OpenGL: NVIDIA GeForce GTX 1660 Ti (NVidia) Memory: 6GB, Driver date: 1-18-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.23
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-18-2024
Driver Version: 31.0.15.5123
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Users\33686\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\D5Conv (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\0.12.0.0028\Rhino 8\D5Conv.rhp “D5 Sync for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\Lands.rhp “Lands Design”
C:\Program Files\Common Files\McNeel\Rhinoceros\8.0\Plug-ins\TeDAsharp (ce983e9d-72de-4a79-8832-7c374e6e26de)\1.0.8405.22062\TeDaSharp_060.rhp “TeDAsharp” 1.0.8405.22062
C:\Users\33686\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\LadybugTools\1.38.188\Ladybug.RH.Loader.rhp “Ladybug.RH.Loader” 1.38.188.0
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\Pollination\1.48.3\Pollination.RH.Loader.rhp “Pollination.RH.Loader” 1.48.3.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “NavigateurInternet”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “GestionnaireInactivité”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.11.24254.15001
ALIASING.3dm (1.5 MB)
Bonjour @Henry_Boutet_de_Monv
Is the “Réaliste” mode a copy of “Lancer de Rayons”? Could you share the Display Mode along with a file so we can take a look here?
Merci!
Hello Vanessa,
aliasing 2.3dm (2.3 MB)
Réaliste.ini (14.3 KB)
I find also somethink, when i have two object with almost similar size i don’t have aliasing shadow but when i have two objects with very different size i have aliasing
Bonjour @Henry_Boutet_de_Monv - Did you originally create the Réaliste display mode in Rhino 7 and imported it into Rhino 8?
Bonjour @Henry_Boutet_de_Monv - After fiddling some more with the file and the display mode, this is defnitely a shadow map size issue. The shadow map that creates the shadows for the scene has a fixed size. When you add a large object where there are small objects, you will get the type of artifacts you’re seeing for shadows here. This is because the shadow map has to reach the extents of the larger object, so when you zoom in to the smaller objects, the shadows applied in that smaller area look “pixelated”.
If you wish to use a surface plane for shadows, as opposed to the built-in Ground Plane, then select this surface and in the Object Properties panel, uncheck the “Cast Shadows” option. This way the shadow map doesn’t have to spend resources casting shadows on it, yet it will still recieve shadows from the surrounding objects.
Hello Vanessa,
Ok thanks for your investigation !
