Alerter won't accept file selected
In the Alerter dialog, I can select ‘play a sound’, but when I click on the “…” and click on a wav file and return to the dialog, the file/path doesn’t show up in the box. The only way I’ve been able to get it to play a sound is to type the path the .wav file.
Hi Peter - got that, thanks.
https://mcneel.myjetbrains.com/youtrack/issue/RH-43647
