Agiosft Metashape file to Rhino
Can anyone tell me what kind of file format I need to use to import my 3D model from Agisoft Metashape into Rhino?
Thank you!
Natalie
Hi Natalie - which formats can Metashape export?
This is the list of file formats that Rhino can import:
https://docs.mcneel.com/rhino/6/help/en-us/index.htm#fileio/_index_of_import_export_file_types.htm
obj is my choice
I export mesh models from Metashape in .obj format, and import directly into Rhino. In the past I have exported point clouds from Metashape and imported them into Rhino but I have not had a need to do so for a while.
Thank you! This is very helpful.
  • I am looking at which workstation to purchase to create a small models in Rhino, would you mind telling me what you think of the specs below? When I looked at the recommended specs provided by Rhino, it says 250 GB SSD and 2TB hard drive, do I need both?
  • Thank you!
When working with large meshes (millions of faces) imported from MetaShape into Rhino I find an SSD to use as the temporary location of the Rhino to be very useful.
